June
- Maple Shade, NJ
Hi fella's
I had a case of Dejavu today as the identical no start symptoms occurred to me again. Only this time a little over a year later on my 96 XJ.
We'll I get out of work and attempt to start the XJ and all it would do was crank over. I let it sit for awhile, battery tested fine, fuel pump was kicking on, I disconnected the battery to reset the computer, dist cap appeared fine, getting plenty of spark, tried to start it in neutral to rule out the NSS. So after numerous cranks, I finally give in and call AAA. They said anywhere from 60-90 minutes they'd be there. So I say what the hell I'll go out there and try to start it again. I crank her over a couple of times and still no start. Finally I depress the gas pedal completely to the floor and after a couple of cranks it starts up but would not stay running unless I keep my foot on the gas. Soon as I let my foot of the gas it would die. And in order to start it again I had to depress the gas pedal completely to the floor. So I disconnect the battery again, reconnect it and the XJ starts up fine. Idles fine and drives normally. I drove all the way home and turned it off. Attempted to start it again and it started up on the first try.
I'm thinking it has definatley got to be a sensor. Where should I start. I'd hate for this to happen again. Bad enough I got to hear it from the wife because this is the second time it's happened. Last time it cost me a $90 tow charge.
Any advise would be great. Thanks.
June
June
