bimmerjeeper
- USA
I wanted to summarize what to check if your XJ does not start.
Is this a good starting point?
Can you tell me the best ordering?
Also, what can you add to this list?
- Neutral Safety Switch (Try to start in neutral, not park)
- Check battery terminals. (Loose and/or corroded)
- Starter Relay (Fuse #19, kick panel)
- Starter (Hit with hammer)
- Starter (Jump with screwdriver)
- Fuel pressure. 48PSI. Listen for Fuel Pump.
- Crank Position Sensor (CPS)
- Ignition Switch
- Check for spark (How do you do this?)
- Is gas tank empty?
- Bad spark plugs? Bad Coil? Bad ECU? Bad Distributor, Cap, Wires?
