ok after some careful work i think i have some new info for everyone
ok again its a 94 grand cherokee it was factory radio that was in now the speakers worked prior to the radio not having power.
so i checked fuses... good.... so i swapped in a aftermarket, i positively identified the constant and switch 12v lines with my meter and connected ground with ground
I connected the constant 12v to the wires indecated on the radio's instruction manual and the switch 12v to the radio's specified location. i did the same for the ground and for the 8 speaker wires, some colors like blue/red as the wiring diagram states were actually blue/pink but i still connected it to the said wires as indicated... this is about my third time installing a radio.... what am i missing the only wire left from the radio connector(aftermarket) is a blue wire that say it hooks to a ant or amp
but on the OEM harness the only wires left not connected are a orange wire (ill.)
green/red wire (when connected to the blue wire from radio makes a noise coming from the glove box but sounds deeper into the glove box.) and theres also a blue/white wire. i have connected all 3 to the blue wire 1 by 1 n still no sound
the new radio has power but no sound please help
