The main power to the 15 Amp radio fuse (upper right hand quadrant of the fuse block) is from the brown wire at the ignition switch connector. Same power source for the cigar lighter, heater blower motor and other stuff.
Brown wire into the fuse, violet/green wire out of the fuse (radio main switched current). The red wire with a stripe (tan stripe I think) is the constant power for the radio memory and comes from the ETR fuse. The ETR fuse is lower center.
You may have it hooked up wrong or the brown wire at the ignition switch connector is a weak spot and often causes issues.
That brown wire supplies power to the fuses for heater blower motor, horn, turn signals, wipers and others. Figure out if it is just the Radio fuse power in that is giving you issues.
If you need it I have a wiring diagram for the radio wiring, it is a really big drawing and I don't want to post it unless I have to.
