Nealio240z
- Redding, CA
I have a '89 laredo with an 4.0, aw-4, np242 case. My problem is I bought this jeep broken and the previous owner drove it everyday. They were on the freeway and heard a pop, the jeep died, and now there is no foreward or reverse gear. Nothing in 4wd either. I pulled the rear shaft to see if the tail stock is turning and it is turning. The shaft turns slower when the gas is applied and goes into reverse when put in reverse. I dropped the trans pan and everything looks good to me. No clutch media and fluid is not burnt. I started to remove the trans and was thinking it may be something else. Could it be the T-case? Could it be the torque converter? Could the trans not be gettin line pressure? I really need help here. Thanks!
