2001 XJ, AW4, I6, AC
I seem to be having a classic hot soak problem (rough running after re-starting the Jeep after a short stop at a store etc) although it's not been that hot out except for one or two days and now have a CEL P0303 no 3 cylinder misfire. I have had hot soak issues occasionally before but recently this has become very persistent and now I am throwing the P0303 code frequently. I have to sit with the hood up now for about 10 minutes before I can get her running. Once the jeep starts it drives fine but the idle is slightly erratic.
I was thinking of replacing the no 3 injector probably original 150000 miles but for now until I am sure this is the cause I only wanted to replace the no 3 injector rather than all 6. Do you think this would cause any further issues just replacing no 3 will it put the other 5 injectors out of balance?
I have NGKs spark plugs with about 16,000 miles on them and I would think they should be ok at that mileage but I haven't pulled no 3 yet. I wouldn't have thought the coil pack would be a problem because I would expect a misfire on one of the other cylinders (3 coil packs, 6 cylinders). Any advice you could give would be greatly appreciated as this is driving me nuts, I also have to drive about 800 miles next week and would like to resolve this before that trip. Thanks.
