NJ Wheelers look here
lobsterdmb
Just a Lobster Minion
If your from NJ, your voice is needed!
Hi all,
A survey is on the DEP website claiming to be about illegal dumping but I believe there is more at stake, even if you don’t use state park trails much I implore you to take the short survey for all 4 wheelers and it only takes a few minutes.
Also please do as follows: as other groups are trying to take credit for 4WD votes.
So on question 1 check 4WD/Dirt Bike but also in the “ box put 4WD, DO NOT CHECK ANY OTHER BOXES AS IT WILL DIMINISH THE 4WD VOTE.
ON #9 JUST DO OTHER BOX AND WRITE IN 4WD..
Please Take the Illegal Dumping Survey (Posted: 3-21-14)
The NJ Department of Environmental Protection is conducting a survey to measure awareness of the problems and agency responses associated with illegal dumping. The NJDEP will utilize the data collected to understand the effectiveness of outreach efforts and how they can be better targeted.
Thank you for your participation; results can be viewed immediately after completing the survey.
https://www.surveymonkey.com/s/XV9258C
Done, Thanks for the heads up !
DONE
