NIB: Boston Acoustics CRC 2way Center Channel
djblade311
NAXJA Member # 1474
Mission Viejo
I have a brand new in the box, Boston Acoustics CRC 2-Way Center Channel Speaker that I need to sell. Asking $75.
Features:
* 2-way, home theater center channel speaker
* Dual active/passive 4-1/2 inch mid/bass drivers
* Active driver’s unique coaxial phase plug draws heat away from the voice coil, increasing power handling
* Passive driver assists in bass reinforcement with zero port noise
* 1 inch Kortec soft dome tweeter delivers a smooth and natural high-frequency response
* Rigid, internally braced CR cabinet delivers clean sound and sits solidly on most TVs and A/V shelves
* Won't affect TV picture thanks to MagnaGuard magnetic shielding
Specifications:
* Recommended Amplifier Power: 15-100 watts
* Nominal Impedance: 8 ohms
* Frequency Response (3dB): 80Hz-20kHz
* Bass Unit: Active/passive 4-1/2 inch (115mm) copolymer
* Tweeter: 1 inch (25mm) Kortec dome
* Crossover Frequency: 2,500 Hz
* Dimensions (HxWxD): 5-3/4×15-1/2×6-1/2 inches (394×127 x 165mm)
* Weight: 10 lbs (4.5kg)
haha you didnt by chance buy that from woot.com did you?
