oldcancer
- Edmonton, Alberta, Canada
so yesterday i found myself lucky enough to pick up a 92 2door 4.0 with a 3.5inch lift and 31's for 1200 (CDN)......but since it rained last night i've noticed a few electrical issues, each and every one has me stumped, even after searching (im not the best at diagnostics)
so the list is as follows:
wiper blades dont work, even after replacing the motor with known good one from my 94
headlights don't work, yet the high beam light on the dash is constantly on when the headlight switch is on
and when i use my right signal it comes on and stays on, doesnt blink, i assume this could be a burnt out bulb, or maybe the flasher relay
heater blows air only out of the front defrost vent, this im pretty sure is a vacuum related issue though iirc
but while searching the issue yesterday i came across a thread where several people mentioned a certain brown wire in the steering column that takes an immense electrical load, could this be the culprit?
and if it is would it have caused the p/o to have to switch out the ignition lock cylinder due to possible problems there?
