Surfer
- Aberdeen,washington.98520
1998 Cherokee XJ 4.0 LITER 1J4FJ28S7WL164419
9 MNTHS AFTER NEW ENGINE INSTALLED(RAN GREAT WHEN INSTALLED)
ELECTRICAL PROBLEM IN ENGINE WIRING HARNESS?
ALL NEW 5/25/2012
FUEL PUMP - INJECTORS - FLYWHEEL - CRANK POSITION SENSOR
DISTRIBUTER- COIL WIRES and SPARK PLUGS- PCM,BRAIN (DEALERSHIP)
2 OXYGEN SENSORS- MAP SENSOR- THROTTLE BODY SENSOR- AIR TEMP SENSOR
VACUUM CHECK - GOOD COMPRESSION CHECK 151.LBS EACH CYLINDER
SYMPTOM FOR 3 MNTHS.
DOES NOT START FIRST 3 TIMES TRYING TO START AND OR IF IT DOES IT
HAS MISS SO BAD YOU MUST SHUT OFF KEY BUT THE 4TH. TIME STARTING
IT IS DRIVABLE WITH SMALL MISS.
PUT TIMING LIGHT ONTO ANY PLUG WIRE- SEE TIMING LIGHT SKIP A BEAT.
LAST MECHANIC--
NO CRANK PO320 PCM IGNITION DIST SPEED
PO700 743 TRANSMISSION/TORGUE CONVERTER
P1391 CAM/CRANK SIGNAL INTERMITTANT LOSS OF CMP OR CKP
QUESTION,
WHAT WIRE IN ENGINE CHASSIS WIRING NEEDS CHECKED TO CAUSE MISS.
ALL NEW 5/25/2012
LAST MECHANIC--
QUESTION,
