ADam J
- Castle Rock Co
Finally got my '99 4.6L stroker running this weekend ( Accurate Power kit)
Stroker now has 30.6 miles on it since I started it yesterday.
From the get go things just didn't feel right. At first I was thinking it was just running 'rough'. I indexed the distributor which I think helped with a bit of a miss, but nothing for the 'rough' feel.
I think my "rough" engine is actually a vibrating something.
While driving any slightly loose plastic interior trim pieces audibly rattle from the vibration. It's not tooth rattling, but it is VERY noticeable. Definitely not 'right'.
I did install new M.O.R.E. motor mounts. I know these will stiffer than stock, but I haven't even heard of poly vibrating like this.
Vibration is engine speed related only. Stuck it in neutral at 75 and the vibration was still there but still followed engine RPM.
Occurs with clutch in or out.
So I'm thinking the main areas that could cause vibration would be:
-Flywheel ( this was resurfaced )
-Clutch pressure plate ( New Centerforce II )
-Harmonic Balancer ( Original )
-Something internal?? ( I sure hope not...)
How the heck to you isolation these and diagnose a vibration?
Thanks for the help.
I'm getting excited about this thing now that I have felt the power I felt tonight without getting on it and with it not being broken in yet. But I'm really dubious about driving it with this vibration going on.
-Adam-
'99 XJ Sport
-Adam-
'99 XJ Sport
