Neutral Safety Switch Adjustment?
Huntin'Jeep
Millville, N.J.
Replacing this item on my '93 Cherokee 'Country'. Removed the old one, and ready to install the new one. Need some guidance on adjusting it.
In the Chilton's book, it says to "disconnect the shift linkage rod from the shift lever at the transmission, then rotate the shift lever all the way rearward, then forward 2 detent positions to N". Can someone explain this to a novice? Any help will be tremendously appreciated!!
Thanks.
Jeff
This gets beat to death roughly every two weeks and I think everybody gets burned out on the subject. If you don't find what you need in the threads listed below, a search with NSS* will turn up more. Note that the NAXJA search engine requires at least four characters, hence the *.
If you don't find what you need, get back.
