neon injectors and FPR?
jeeptorino68
Lebanon OR
dodge neon fuel injector swap
goign to do this on my 92 4.0 HO engine but had a few more questions
i am getting the EV6 4 hole injectors from a neon part number 0280155703 they are rated 22.6 lbs
91-93 4.0 have 21 lb injectors at 39 psi.
do i need to change to the later style FPR to run the neon injectors?
here is what i was reading:
http://www.ausjeepoffroad.com/forum/showthread.php?t=92236
"91-95 Jeeps with Fuel Pressure Regulators (FPR) on the fuel rail.
Stock FPR Chrysler # 5303 0001 Supplies 31psi @ Idle and 39PSI @ WOT
Chrysler # 4418850 or 5277829 or 5277864 (Manufacturer: Delphi, Part#FP10046) Supplies 40psi @ Idle and 48PSI @ WOT Drops straight in, no modifications. ~$40USD on US fleabay. (thanks to coas from cherokeeforum)"
but i have no idea what PSI the neon injectors require
thanks
thanks for the info i just wanted to confirm this conversion will work with the FPR i have on the jeep right now. i thought it would but i couldn't find where i read that.
thanks
