need welding lessons? help fabricating something contact me..
skycrawler
Delta
iam currently looking for some side/ part time welding work for the nexted year to get by untill im done with SARG training.
I can weld struct, pipe. In every position and every process along with brazing ect. everything from Carbon steel, titanium, stainless, aluminum so on.
thanks
Where u located? Cause I have an old arc welder someone gave me and I can't get it to lay a bead. I have zero experience so I'm not sure if the welder is shot or if it is just me being a noob at it.
im in Boulder/lafayette co area.. most likely all your connections just need to be cleaned up. what rods and what steel are you trying to lay a bead on?
whatever you think is reasonable . cheaper if you have your own unit you want to learn on. im just looking at passing on the knowledge i have and make enough to get by in the process.
I would be interested I was going to take some of the MIG classes from General Air but they fill up so fast. They are pretty reasonable on the class prices.
I have my own welder. I have been practicing some but would like to learn. PM me some prices ( I am in the Highlands Ranch area).
thanks!
