fourplayoffroad
- gresham OR
so I want to wheel real bad but I keep breaking the left front shaft right at the ears where the u-joint caps go in. I plan on going with a D44 front early next year so I need to try to make this D30 last a little longer. I can get a brand new inner and outer 297 shaft with u-joint for $105 or get a used one from a wrecking yard for $60 is that over priced for a used shaft? I've called almost every wrecking yard around and this is the only one I've found. I would like to keep this as low budget as possible but also want to wheel the crushers again at least once along with many other trips elsewhere. My second question is I'm buying a new carrier for $52 should I just run open diff. (wont be able to run the crushers) or spend the $280 for a lockright? I'm running 35s and 4.56 gears and I've been told that it should hold up ok for a while but right now I'm welded in the front and I'm pretty sure thats why I keep breaking that shaft. Whats your input????
