Hey this is my first time on here. So i have a 95 cherokee sport with about 150,000 miles.
Well when i put it in reverse from park it clunks in the rear end. it also clunks when you let off the gas. I visually checked the mounts and they all seem to be ok. I think it might be the U joints.
I read on here that you can test it by putting the jeep in nuteral and seeing if the drive shaft has any play in it. Well I did that test and it does rotate 1/4 inch or less each direction. I wasent sure if i tested it right, so if someone can give me some insight on this issue would be great.
Also it seems like the fan comes on alot(like ever 10 seconds or so). The gage doesent say that its overheating. Any one know anything about that? thanks for any info.
