I am wondering where can I get stock replacement rear leaf springs for my 99 cherokee cuz the 1's in there r screwed. i was thinking 3 inch lift leaf springs and was wondering if i put 3 inch lift coil springs in the front, what else would i need for the lift, extended shocks and brakes lines??
You will need longer shocks. Several manufacturers make 3" lifts. I run a Rusty's 3" SP lift on two XJ's.It comes with new front and rear springs shocks and brake line adapters and instructions. About $400 plus shipping.
You will need longer shocks. Several manufacturers make 3" lifts. I run a Rusty's 3" SP lift on two XJ's.It comes with new front and rear springs shocks and brake line adapters and instructions. About $400.
x2 All you really need for that small of a lift is longer shocks. Some kits do come with a brake line relocation bracket kit which relocates the position of the brake lines to give them a little bit of extra length, just in case.
