dizzymac said:What TC 231/242?
Jess said:how do you know no fluid is going to the rear?
was there any recent work to the brakes?
pokeyxj said:As far as the rear brakes...My guess would be the proportioning valve. It's the block below the master cylinder that the brake lines go to. There is a switch in the middle that should activate the warning light on the dash. Try removing the switch, slowly push the brake pedal to center the valve then replace the switch. Other things could be the master cylinder, a clogged/crushed line, ABS pump.
pokeyxj said:... the proportioning valve. It's the block below the master cylinder that the brake lines go to. There is a switch in the middle that should activate the warning light on the dash. Try removing the switch, slowly push the brake pedal to center the valve then replace the switch.
