shanebringman
- kenosha wi
Ok here is what is going on i have a home made 3" lift on my xj and i bent a front axle tab. So i pulled out the front axle and made and re welded a new one in.
I pulled all the numbers right every thing bolted back together like it should but now its like the front drive shaft is to short. The only thing that has changed is i cut out the sway bar links and the truck always had them, but that shouldn't effect the drive shaft
I have no clue what i did but if anyone has any input that could help me get my xj back in the mud. thanks for your time and help
