Need Help Mile Marker Man Hub Install
Cipey
Beachmont, MA
Mile Marker Hub Studs
Hey there folks.., here is a photo of the MM Man Hub:
as you can see, the studs will not fit into the hub, no clearence. is this why full cast rotors are needed to press the studs directly into the rotor intself?Or do i have to loosen up the hub with a provided special socket and install the studs directly into the hub? it really doesn't say in the instructions. except that Full Cast rotors must be used and they must be machined (rotor pilot home) a bit so the hub will sit flush. I know a lot of you guys that have done this mod don't have any exp. with the MM kit, but I figured the Warn kit must be similar.
Thanks
Cipey
