3percenter
- Alabama
So for a few weeks now I've had this clunking under my jeep that I cannot find. It is a repetitive clunking and squeaking noise under 40mph. It only happens when accelerating or decelerating in gear. My jeep is a 97 xj lifted 6.5" with 5 speed trans, np231j transfer case, Chrysler 8.25 rear d30 front, has sye kit. I have changed fluid in transfer case and both diffs. I have also added grease to the rear driveshaft. I removed the front driveshaft and check all ujoints front and rear. I have check all mounts and all suspension for loose bolts. I have done all of this with no luck. Any help will be greatly appreciated.
