- Lake Forest, CA
Ok so after everything i have done to my XJ i am going to need bump stops (Front & Rear) now before i do any serous roading. I know there is a few threads about bump stops but they require welding and i don't have a welder. But maybe it would be cheaper to custom make the rear at least and pay someone to weld up an extended plate on top of the leaf spring U bolt plate with a support on top of the axle tube.
What works for your Jeep and what manufacture/part numbers do you have to make it easy?
Thanks, Brandon
Thanks, Brandon
