Need an answer really fast
Alienspecimen
Best Coast RI
99 XJ 4WD 188K
My oil filler cap will not unscrew. I am turning it counterclockwise and all it does is click as it turns, but does not unscrew. I need to leave now and there is no oil in the engine.
What are my options?
Transfer oil into a smaller container if need be, then with it, and/or in addition to a small funnel, ready made, or home made, pour oil down dip-stick tube.
I had the same issue the last time I changed the oil in mine. Took a large pair of pliers, ripped the upper half of the cap off, and was then able to remove the threaded half to fill it up with oil. Reinstalled the threaded section, drove to OReilly, bought new cap.
edit: yep, exactly like that. ^
This is how I did mine only I threw the top half in trash and just use the threaded part.
Wow. hahahaha you guys crack me up. You know the cap is designed to do that. Dont worry about breaking it but twist counter clockwise hard. It will pop loose
Oh gee, thanks Mr Obvious. I guess no one thought to try turning it counterclockwise.
Oh, except for everyone who has had a cap break on them.
Has the Alienspecimen left yet?
