I posted this question in the "terminator EFI" build thread I have going , but this is distinct enough I think it warrants its own thread..
I have a 350 in my 88 cheorkee, originally went carb'd, now I'm installing a terminator efi. I've decided to go all stainless (304, .28 wall diameter) fuel lines rather than flexible.... using all an -6 fittings.
I'm having a hell of a time making the connections leak proof, making my own flares. After making all the flares, I pressurized the pump, and every single one of the connections leaked. I then realized that the @#$#@'n cheapo tool I was using was a 45 degree flaring tool, not a 37 degree flaring tool.
So, I bought rigid's awesome 37 degree tool and this (http://www.amazon.com/Ridgid-41162-...TF8&qid=1450024134&sr=8-2&keywords=ridgid+377) and this (http://www.amazon.com/Universal-Hydr...lic+flare+tool). both make perfect 37 degree flares.
I re-did each connection, making sure to prep each section meticulously before making the flare. reconnected everything, and each of my flares was still leaking. Each connection is stress-free (I.e., I'm not using the connection itself to pull the tube together).
What else can I look at? the only thing I can think of is that I'm using welded tube .... is it possible that the seam is interfering with the mating surface? will seamless tube make a difference (I don't mind spending the money on this, but if it's not going to work don't want to waste the time or $$).
I'v bought a few of the flare savers earl's sells -- these are basically 37degree "hats" you put on the male side of the connection, it's made out of aluminim, so it's kind of like a metal gasket. I've heard guys swear by these things... any experience with them?
I've started from zero knowledge or experience on this, I've managed to go from tank to tbi using all stainless... I'd hate to scrap now after all the time and $$ I've spent and go with braided stainless flexible line. There has to be something fundamental I'm missing.
