need a mirror
Just swap to 97-up!
If you cut the power wires and use the plastic backing plate from the 97+ they work just like manual that you adjust on the outside..that's what I did on my Heep. Or I might have just shoved the plug into the door frame.. Either way it works. If Pat passes on the mirrors, lmk what you want for them Josh.
Thanks Pat, If you REALLY need a mirror, I have a really rough drivers (needs paint, and clips "repaired" with spray foam or gorrilla glue) and it has shattered mirror portion. Free to you or anyone who wants it.
EDIT: Foam/glue expansion can blend in with a coat of Paint. It was done cleanly and smoothed out to where I didn't even notice it at first
