98savages
- Hampton, VA
Good evening,
I bought a 1998XJ sport back in June. It had the airbag light on when I bought it. The previous owner thought it was a clock spring, so he replaced that. They’re a bag light was still on after that.
I noticed that the light does not stay on constant, sometimes it will go off while I’m driving down the road but I learned not to hold my breath as it always comes back on again eventually during the same trip.
I put the run the wiring and noticed that the wires going to the seatbelt were severed, so I spliced and reconnected using push connectors. Both wires are black so I wasn’t sure which side they should be on but I swapped the connection and there was no change in the airbag light.
I took the jeep to the dealership to have them read the airbag light codes. These are the mechanics notes:
“Airbag light comes on intermittently. Checked airbag light on, check vehicle for codes, no NE found active or stored, have communication, have proper power and ground supplies to controllers, MIC says ORC commanding light on, ORC states light commanded on however no codes, suspect internal short in ORC module, must replace ORC with known good new component before any further diagnosis can be performed but I’m relatively positive ORC will fix problem.”
They quoted me $500 to replace this airbag control module. I found a new one on eBay for 65 bucks And I’m confident in my ability to install it myself per several write ups that I have read over the past few months regarding this issue.
I was just wondering if anyone had a second opinion regarding the situation, whether anyone can confirm and agree with the mechanics diagnosis, etc. before I go ahead with this fix.
I think the real reason why am asking this question is because of the fact of the light comes on and off intermittently. If the airbag control module was bad, wouldn’t the light stay on constantly? I’m probably wrong about that, so I just wanted to post this and be sure. The only stupid question is on you don’t ask, right? I did use the search function and read through 10 pages of posts and haven’t come across anything like what I’m dealing with.
Thanks so much for your time.
