Name That Part, Please
alexgalexg
Connecticut
1999 XJ I6 4WD
1. I need the official name of the shaft on the left. It should represent the front passenger axle shaft.
2. Who sells it for a reasonable price?
Thanks in advance.
P.S. The FSM calls it a shaft yoke and when I search, only parts for the drive shaft come up.
If I understand you correctly, that is passenger side front axle shaft.
wwwrockauto.com
USA STANDARD GEAR Part # ZAW38875 4340 Chrome-Moly Axle; uses 5-760X U/Joint $106
Inner axle shaft and outer stub axle shaft.
They are cheapest at the junkyard. Unless damaged or abused, used axle shaft will work well.
