aparke4
- Atlanta, Ga
hey this is going to be done over the next week so bear with me!
cage is starting this week with www.whiterhinofab.com here in MS
cage will tie into rear bumper and will be flanged in case bumper needs removal
plans: cage rear out w/ tire carrier
cant decide on making gas tank skid or cutting floor and moving it up - the space as it is now is nice to have
mount wrangler rear bench in back
making tube doors now -almost done- and going to have heavy duty vinyl snap ins for rain - going to cut up stock doors and make a skin off the outside so they can bolt on to tube doors to retain body lines
tie in front stinger to front tube fenders which are yet to be built and then into rock rails - tube from stinger is going to run through header panel
maybe some exo tube work like a spreader over wipers and a low profile roof rack that would tie into cage and front tubing which is not done yet
take off stock tail light housing - use sheet metal to cap off rear and mount my 6 inch sealed LED lights using trailor wiring
also put on currie HD steering with is super stout - also have alloy inners and new u joints which should go in tonight hopefully on the dana 30 which i am getting shafts for soon also from alloy
