ColoradoDave
- Seattle
Hi. first off, 92xj 4.0 5spd np231, rustys 3 inch, 260k and still kickin.
I've been chasing oil leaks for awhile and recently replaced the valve cover gasket and the oil filter adapter O rings. On the freeway yesterday I notice I'm burning oil and leaving a smoke trail thick enough to get lost in. I pull over and find oil pouring off the front of the transmission and dripping all over the exhaust pipe hence the smoke. Limped it home. spent a few hours cleaning today to track down my leak and found I'm leaking from either the rear main or the oil pan gasket I don't really care which I'll replace them both. My problem is I'm not convinced those are the only leaks. I can't find any trace of oil leaking from the filter adapter, distributor, head gasket, or valve cover gasket but before I cleaned there was oil sprayed all the way up on the hood and over the plug wires, I mean everything was covered in oil!
So, my question is, could an oil pan gasket or a rear main spray that much oil forward by themselves? has anyone seen this before?
thanks, sorry for rambling.
