freerider15
- FoCo, Crawlorado
So it's looking like I'll be moving AGAIN here in a couple months...
I've moved enough crap...and don't want to keep moving some of it.
I work off 120th/I-25 so I can meet in north denver.
This will get updated as I go through things:
Jeep/4x4 Stuff:
- C4x4 Tow Hooks and Brackets setup, in good condition just kept it around since I was always planning on putting it on another XJ - $50
- Magnaflow Muffler: 2.5" Inlet/Outlet, taken off my Jeep, worked fine just wouldn't fit in the buggy - $20
- Shock Hoop: Mount inside between the wheel wells to run shocks through the floor. 2" x .25" box tube, 1/4" mounts, hardware included.
- Gas tank w/ fuel pump off my '98 - $20
- ProComp Lower Control Arms: 16" Eye to Eye - $40
- Yukon D35 Passenger Side Alloy Shaft - $30
- 39.5x15R15 TSL Swamper Bias: 99% Tread left (nearly brand new). It has cuts it the sidewalls and does not hold air. Was just going to throw a tube in it and it would make a good spare. Found a spare 42 for the buggy so don't need it anymore - $40
Ballistic Fab HD Link Tabs 3/8" thick, 9/16" hole - Short (1.5" between hole and mounting surface) - $5 per pair, 2 pairs available
Specs:
http://www.ballisticfabrication.com/HD-Link-Tabs-175_p_1601.html
Ballistic Fab HD Link Tabs 3/8" thick, 9/16" hole - Short (1.5" between hole and mounting surface) - $7 per pair, 2 pairs available
Specs:
Ballistic Fab Multi-purpose Tabs: 1/4" thick, 9/16" hole - $2 per pair, 4 pairs available
Specs:
http://www.ballisticfabrication.com/Multi-Purpose-Tabs_p_1476.html
Ballistic Fab Axle Tube Link Tabs: 3/8" thick, 3" tube, 2.5" between hole and mounting surface, 9/16" hole. $4 per pair, 2 pairs available.
http://www.ballisticfabrication.com/Axle-Tube-LINK-Tabs_p_1720.html
Ballistic Fab Axle Tube Link Tabs: 3/8" thick, 3" tube, 1.5" between hole and mounting surface, 9/16" hole. $4 per pair, 2 pairs available.
RuffStuff Bushed DOM Sleeve: 1/2" Sleeve ID, 3" Overall Width, 2" x .25" sleeve, zerk fitting.
$16 each, 5 available.
http://www.ruffstuffspecialties.com/catalog/merchant.mvc?
Non-Jeep
- (4) Ford Wheels with caps, 8 on 170mm - $120
- Ford 3rd brakelight (top of cab one) off my '99 - $10
- Ford Passenger Side tail light off my '99 - $20
- (4) 265/75R16 Wildcat All Terrain Tires, few miles still left on them - $40
- Serta Kendell Twin Mattress, The matress is a "firm" mattress and is in great shape,was the top mattress on a bunk bed that got used a hand full of times. - $40
FREE:
- Stock Upper Control Arm, never used, bushing still good
- Jeep glass: Both rear doors, rear quarters and heated hatch, not tinted all of my '91
Jeep/4x4 Stuff:
Specs:
Specs:
Specs:
Non-Jeep
FREE:
