motor mounts..
Weasel
yes this has been covered before and it seems MORE is the way to go but anyone have any expirence with Raw Brown motor mounts?
http://www.rawbrown.com/
And does MORE offer their torsion rubber mount in bare steel? I've only found the zinc coated ones but the non zinc run a bit cheaper.
Mine are pretty shot, enough that the downpipe can move enough to hit the front driveshaft on hard turns.
also I was noticing that the wranglers can use a 1" lift to help reduce driveline vibes, could this be used on a XJ? I think I would have enough clerance under the hood for the lift, or is it even worth it?
I have had good experience with Rawbrown motor mounts... they have been in my jeep for 2 years.:D
well good. :D I see you listed the duro reading on your site, how does that compare to the rubber that MORE uses? I believe they use a control arm bushing.
