Black2doorXJ
- Massachusetts
My heat has been working on all cycles.. it turns off when I slide the top slider to off, but it is alwasy on, one speed, and it isn't high it is like speed 2 maybe.. I replaced the resistor under the pass. side dash, and then I even got a new blower motor as the other one was all rusty and I figured that was the prob, but I guess it wasn't. The heat control module under the hood cracked and sprayed coolant everywhere and was just replaced, but the problem was happening before that. I have also checked and have no vacuum leaks. Not sure if it is related, but the dome light comes on when it wants to as well.
