does anyone happen to know of any gm or other motors that will bolt up to the auto. tranny in my 86 mj 2.8, its an s10 motor i know but i dont know if anything bolts up to that, i believe its a chrysler 727 trans.
Or an S-10/T-15. You can use a V6-60 from a RWD/4WD vehicle (truck or F-body being the best donors,) but not a FWD - the starter will be on the wrong side, and you won't be able to get it to bolt up.
That bellhousing pattern is also shared by:
Buick later 3.8L V6 (RWD)
Cadillac 4.1/4.5/4.9L V8 (don't know if the starter is on the wrong side offhand)
1984-1993 Pontiac I4-151ci RWD(a vastly superior engine.)
And is known as the "GM Metric" Bellhousing pattern. The various "small block" and "big block" GM engines will not fit (but they also share a common pattern,) however the bellhousing of your transmission is, I believe, removable - so it could be swapped in toto. It's a Chrysler transmission, so you may have an easier time swapping to a Chrysler engine going that route - I'm still collecting information there.
However, the F-Body/Truck V6-60 will be the easiest swap, since you don't have to modify the engine mounting as well.
