99NCXJ
- Belmont, NC
I've lowered the prices on most of this so come get it.
XJ Parts-
1988 XJ Shell very minor damage on rear corner and dent in one door. With Title 200.00
NP231 100.00
D35 with 3.07's 75.00
or set of axle shafts from 35 for 50.00
(4) aluminum Eccos jeep xj wheels 200.00
rear hatch with glass (no wiper type) 45.00
alternator 30.00
power steering pump 30.00
power steering box 50.00
intake manifold 30.00
throttle body with intake boot 40.00
radiator suport 30.00
factory header pannel for xj. no grill, just the header pannel 40.00
in tank fuel pump 25.00
steering gear box 40.00
Dana HP 30 (non vac. disco) housing with knuckles 50.00
Dana HP 30 (vac disco) housing with knuckles 50.00
D30 carrier, 3.55 ring gear 30.00
Chry. 8.25 housing 50.00
ZJ Parts-
stock zj rear coils 30.00/pair(from V8)
glove box and door 15.00
washer fluid tank. 5.00
steering column with steering wheel and air bag 50.00
steering shaft 10.00
over head console 20.00
headlights 15.00
dash controlls 15.00
radiator support (5.2L) with hood latch 25.00
gas pedal assy. 10.00
brake pedal assy. 10.00
transfercase shifter assy. 10.00
polly gas tank (was going to be used as fuel cell) 50.00
air box…5.2L 10.00
front door glass. Driver and pass. Side. 10.00 each.
MJ parts
stock drag link 15.00
stock tie rod 10.00
brake booster/m.c. 25.00
prop. valve (under mc) 15.00
prop. valve (above rear axle
lots of dash parts, guages, pedals, bench seat,
AW4 tranny 21 spline 150.00
NP231 21 spline 100.00
Drop in bedliner for long bed comanche 100.00
MJ fuel tank, no sender. 10.00
Misc. Parts-
lower coil buckets for radius arms 10.00
(2) Dana 44 diff covers 10.00 each.
(2) dana 30 diff covers 10.00 each
TJ stock front springs 25.00
1972 Honda QA50 dirtbike
collector bike
is in parts in a box. frame has been painted. 150.00
XJ Parts-
NP231 100.00
alternator 30.00
ZJ Parts-
headlights 15.00
air box…5.2L 10.00
MJ parts
stock tie rod 10.00
Misc. Parts-
collector bike
