Media blasting helmet/hood recommendations?
anthrax323
San Antonio, TX
So the sandblasting of my spare/project axles has hit a standstill due to several reasons, but the biggest reason now is the weather. Here in NC, the humidity has started to set in with a heavy fist, which results in me only having about 5 minutes to media blast before the lens of my Horrible Freight mask fogs up and leaves me blind.
http://www.harborfreight.com/abrasive-blasting-hood-38138.html
Does anyone have any recommendations for alternatives that are ventilated well enough to mitigate this issue? I've done the goggle/mask combo a few times, but honestly, I wasn't comfortable with how much aluminum oxide ended up in my ears (might just have to plug them, I guess).
Thanks in advance guys (as always).
Further research points to the fact that I might want to consider investing in a supplied air system mask/helmet setup if I'll be working with potentially hazardous materials in the future (such as silica, if I had actually gone through with using playground sand for blasting rather than aluminum oxide). The entry level into this arena seems to be around the $400 mark - does that sound about right?
Don't blame HF. Those types of hoods simply have that problem. The only way to get away from it is to use a hood with an external powered air source and a hose.
Hell,you can buy a blast cabinet alot cheaper than that!
