Lightfoot
- fort collins co
IM working on installing a 99 HO short block in a 90 renix with an aw4 and im having problems getting the engine and transmission to mate all the way. I got it all but 1/2 inch, and cant get it to go the last little bit. This is my first motor swap with an Automatic transmission, so im affraid I might be missing something. THis is very similar to when I used the wrong pilot bearing when installing the stroker in my 99, however there was no bearing in the crank of the renix motor I pulled out. I simply removed the flex plate and TC and installed them on the other motor. The newer engine did originaly come from a manual xj but that should not matter should it? Am I missing something that would make this go a little easier? Thank you
Lightfoot
Lightfoot
