Boneless-Jeeper
- Arlington,WA
1991 cherokee 4.0 liter 5-speed
ok so my computer is flashin at me code blah blah which is the map sensor,so I ran to tacompton and stole my buddies map off his 89 wrangler 4 banger (its getttin a blown 350) same sensor i'm pretty sure right ? ,and I know its good because his jeep ran great so I threw the sensor on and Im still gettin a map code and symptoms .
symptoms: are that some times during acceleration it kind of bogs or skips ,and at idle it runs way to low around like 350-600 rpm or somewhere at like 1000 also when you blip the throttle itll go up then run wayyyyyy down low and come up to like a steady 650 if yall need a better description just lemme know !
thanks guys for any input in advance !
