Map Sensor Adjuster/Enhancer
Cburb88XJ
Purcellville, VA
Excuse me for asking, but what is the purpose of this? From the ebay add, it looks like it has terrible idea/engine damage written all over it. Not questioning your knowledge, just trying to understand why someone would want to limit the MAF sensor voltage.
On xjs it's used for the map sensor. Adjusting voltage will change how rich it runs. Increase voltage is richer, decrease is leaner. Mainly for modded engines like strokers.
Somewhat correct, but depends on the year. Later models will always calibrate mixture based on the O2 sensors. The map sensor is an indicator of load which feeds the selection of open loop versus closed loop. It's not really dial-a-mixture.
(Waiting for cal or tayln to tell me I'm wrong as it happens often)
Yea mines obd1, never did read into the difference between the adjuster on obd1 and 2.
Jeff at stroked jeep isn't making anymore adjusters in the near future he said.
Not 100% true. The later PCMs will try to stay in closed loop longer, but they do still rely on the MAP sensor. It can be said that it is true if you are speaking in terms of the stored fuel trims to provide calibration. A MAP adjuster, however, will do 100% of nothing for air fuel ratio in closed loop operation.
While the MAP does contribute to open/closed loop switch it and does play heavily in ignition timing and open loop fuel mix. I did run an Apexi SAFCII successfully for years which is basically a MAP adjuster with a bunch more points to change.
Gah.. didn't see his until I was replying
As for the use for the MAP adjuster unless you have a wide band O2 sensor setup you will have no idea what your changes are doing in open loop.
Doesn't bother me. The older I get the more I realize I learn 3 times as much being wrong than being right all the time.
Yeah, I forgot about this. Having an AFR gauge is critical.
