helliphinon8
- Queen Creek, AZ
I have a 98 XJ with 156k on the clock, also has 33's and stock gears. I recently have had a problem with it not shifting into overdrive, it's currently shooting the following codes... P0705, tranny range sensor. P0740, Torque Converter Clutch Solenoid. P0700, Tranny Control System. My ? is... What sensor do I change? And where is it??
Also a new development, today it started idling rough and misfiring. It threw a P0305 code, cylinder misfire on cyl #5. Probable cause...bad plug, bad coil, vacuum leak, high or low fuel pressure. It has a new cap and rotor and new wires. The plugs have 50k on them. WTF? :banghead:
