The knob broke off my shift, im just wondering before i go playing with it, does the shifter just thread onto the linkage coming from the trans? If not how to you remove it?
Not sure I get your question--the knob screws onto the end of the shifter.
If you want to remove the shifter there are four bolts that hold it to the transmission.
If you want to replace shift boots you need to split the shifter at the "bulge" by using two small flat-blade screwdrivers or two pieces of hacksaw blade to release the clips and then knock it apart with a mallet while its held in a vise.
