jdxj
- Colorado Springs
So I bought a non running 2000 XJ sport 4.0 yada yada tottally stock.
previous owner replaced the MAP, TPS, Coil rail, Injectors,Computer,Cam sensor,
Still wouldn't run so I got it for a steal. I've replace the coil again, Idle control motor, swaped the original computer back in, and the Crank sensor,
after the crank sensor it starts but still runs like crap.
It starts and runs great for about 30 seconds then it start to idle rough and if you try and drive it it just falls on its face spitting and sputtering, I'm kinda lost.
I have a good running 01 sitting out in the driveway too so i can swap parts back and forth at no $cost just time but honestly i dont know where to go from here.
Everytime i hook it up to the scanner it gives me a different code,
Ive had 1391,0100,0152,0351,0352,o2 sensor code cant remember the number,
and everytime i shut it off and reset the codes it comes up with a different code next start up.
I did check the Vin on the jeep and the vin on the computer do match,
The code its throwing now is p0100 MAF sensor circuit, :twak:I thought jeeps didnt use a MAF?
WTF please help
ANY IDEAS
WTF please help
ANY IDEAS
