Boostwerks.com
- Colorado
Liquidating some of the spare parts I have laying around...
All prices are picked up. Contact me for a shipped price.
1. New long side D30 shaft (Nitro chromo) - $75
2. CO2 tank in great shape - $40
3. Set of 4 new QA1 5/8" Chromoly Heims, and Ballistic Fab tube adapters (2 RH, 2 LH). Tube adapters are for 1.25" OD 1" ID DOM. Includes Jam nuts. $100
4. New Daystar poly sway bar bushings for a factory bar $20
5. Ballistic Fab heavy duty link brackets Tig welded. 2.63" joint width, 9/16" holes. $40
6. Factory D30 Carrier with 3.55 gears with pinion gear. $Free
7. Factory 29sp 8.25 Carrier with 3.55 gears (no pinion). Great and cheap way to upgrade to 29sp shafts! $25
8. New Crown D30 ball joints. Removed for picture purposes only. Does not come with threaded knuckle inserts, so will only work on 90+ models. $75
9. RE extended SS brake lines slightly used but in good shape (up to 4.5" lift). $30
Thanks for looking!
Bryson
Thanks for looking!
Bryson
