sickandtwisted
- so cal
Not that I'm going to run it, but I'm leaning toward what I can only explain as a KOH inspired build, (being able to take it through the desert and bomb it but still be plenty capable of crawling trails)
which leaves me scavenging old threads :compwork: looking for info and my head spinning.
Right now I'm looking to get my suspension dialed in... What I'm thinking to do for now is just get the front setup: bumped and strapped with good shocks and just something to hold me over in the rear till I'm ready to cage it and go through the floor.
I'm leaning toward a 9100 front and a 5100 rear (for now) Then I start thinking... Is that good enough? Would it be worth it to do bypasses? Even coilovers?
My mounts in front are stock so I'm at a bit of a loss as far as the mounting... JKS style or T&J style conversion? Should I change my lower mount as well? I know coilovers will bring on a whole new set of obstacles so we'll just sideline that idea at the moment (unless it is definitely the way to go)
I also wonder should I continue to work with the Dana 30 up front or scrap it and go with a Rubi 44 or something?
To give some info on the rig: I'm Running RE long arms 5.5" coils, and ACOS front with 5.5" RE leafs JKS shackles and JKS crossover shock mount rear
Again I'm not racing but I do plan on using it like I am
