PN# 6161K11 114" Length Turn-To-Lock Knob-Control Cable Assembly In stock at $32.00 Each
this is at
www.mcmaster.com page 1061
I plan to use this locking push-pull cable to build a posi-lock for about $40-50.
Knob-Control Cable Assemblies Also known as power take-offs, just turn the knob on these assemblies to create the push/pull motion you need to operate valves, chokes, and throttles from a remote location. All have a control cable with Type 303 stainless steel core and polyethylene conduit cover that can be cut to length. The cable is flexible so you can snake it around bends and obstacles. Control knob is phenolic plastic. Temperature range is -65° to +225° F.
All assemblies can be panel mounted (see table for mounting thread size).
Nonlocking assemblies provide smooth, easy operation.
Turn-to-lock assemblies are perfect where severe vibration is a concern. Just pull and turn the handle to its locking position.
Precision assembly has turn-to-lock control with a vernier knob for fine tuning throttle positions.
Nonlocking
Turn-to-Lock
Cable Dynamic Min. Mounting Cable Cable Core Max. Push/Pull Bend Thread Handle
Lg. (A) OD (B) Dia. (C) Stroke Load, lbs. Radius Size Dia. Each
Nonlocking 128" 0.31" 0.085" 5" 100 6" 1/2"-20 2"
6059K1 $23.98
188" 0.31" 0.085" 5" 100 6" 1/2"-20 2"
6059K7 27.73
Turn-to-Lock 114" 0.25" 0.085" 3" 100 6" 5/8"-18 2 1/2"
6161K11 32.00
186" 0.25" 0.085" 3" 100 6" 5/8"-18 2 1/2"
6161K12 38.45
306" 0.25" 0.085" 3" 100 6" 5/8"-18 2 1/2"
6161K13 49.03
Precision 65" 0.31" 0.085" 3" 30 6" 3/4"-16 2"
6059K4 32.44
Precision
