RE-xtremeXJ
- Smithtown, NY
I have been searching but havent really found any specifics on limit strap mounting locations. I just installed a clayton long arm and have the RE 5.5" kit with 1.75" coil spacers. I was thinking about mounting the lower end of the strap to UCA bolt where it meets the lower radius arm and mount the top to the fatory UCA framt mount. Possibly inserting a spacer block between the frame and intide mounting flange to distribute the weight.
Im sure someone has a similar setup so im looking more or better mounting ideas. Pics tell a thousand words..
