Sarge
- St Louis, MO
I'm a sewer and drain tech. The main line machine runs about 275 lbs and can wear ya out on a busy day getting it in and out of the van. I've been considering mounting a small winch in the van and using it to get the machine in and out. A friend did this using a small boat winch and it works good but his is slower than crap.
Any one have any experience with the small winches? Maybe ATV winches? All I really need strength wise is around 500 lbs. Would like it to be reasonably guick...I can get the machine in and out fairly fast without the winch and even if it were a lot easier would most likely not use it if it were too slow.
Sarge
Sarge
