What brand of oil filter are you using? Fram has a notoriously bad anti-drainback valve that allows for dry starts. I switched to Wix (Napa Gold) on my 4.0 and quieted a lot of the noise.
On high mileage engines, you're never going to eliminate the lifter noise entirely.
I noticed a low RPM lifter tap when Jiffy Lube put in 10w30 instead of straight 30 like I wanted. Straight 30 is all I've ever used. I'm in Houston, it's always hot here.
