00xj
- West Michigan
Hi all,
It's time for me to sell my Jeep. My intrested have turned elsewhere, and I don't seem to have time to wheel.
Here it is, if you have any questions or would like to talk to me my number is 1/231-924.1648, I live 1 hour north of Grand Rapids in Michigan. Thanks
Red 2000 Jeep Cherokee 4wd Sport $10,700 63k miles 4-door
4.0 Power Tec I-6 w 4 speed Automatic transmission
Selec-Trac Full Time 4wd System (242 t-case)
Air Conditioning, Power Windows and Locks, Keyless Entry
Power fold-away mirrors, Leather wrapped Tilt Steering
Roof Rack, Floor mats front and rear
Trailer Towing package (larger radiator, transmission cooler, class three hitch)
Tinted Glass, Cruise Control, Am/Fm/Cd/Equalizer, Agate Cloth interior
Extras
3-inch lift kit , consisting of;
Front, Black Diamond 3in. front springs, lower control arms, heavy-duty adjustable track bar, noisy homemade disconnects. Black Diamond hydraulic shocks.
Rear, Rubicon Express 3.5 inch super duty 6 leaf packs. Sway bar removed.Monroe gas shocks, extended stainless rear brake lines.
All lift parts were new when installed this spring and are working properly.
Drive Train
Rear, Tom Woods SYE with double cardan drive shaft.
(new t-case main shaft output bearing w/install)
Front, Front shaft has been complete rebuilt, all new u-joints and slip yoke.
Front axle has recently had all pinion bearings, carrier bearings and yoke replace by dealership.
Extras
5ea, 31x10.5in BFG Long Trails
Mopar front and gas tank skid plates, SkidRow t-case skid plate
All J Products, Boulder Bars (rock rails)
Front reinforced Mopar tow hooks, rear hitch mounted tow hook
Mopar brush guard
Mopar front and rear mud flaps
Husky Liners; front and cargo area,
2, 4in. x 27ft, tow straps, 1, 2in.x 25 ft strap,
Condition
Front grille and radiators were replaced due to a small accident. Hood and fenders were not harmed. The right front wheel is out of camber by .1 degrees. Factory allows –0.8 to 0.5, it is at –0.9. This causes a slight “pull” on long wide corners, no shaking, death wobble or drifting occurs at any speed, tires are wearing normally and vehicle tracks straight at all speeds. This can be corrected with an offset ball joint, (if you care). Vehicle is Good condition with no rust. Interior is in great condition. One dent in lower passenger side doors. Some tree branch pin striping.
Oil changes preformed every 3 to 4,000 miles.
Front brake pads replaced at 58K.
Call or pm me if you need more information.
Thanks,
Tom
Extras
Drive Train
Extras
Mopar brush guard
Condition
Thanks,
Tom
