less then 2 months!!!!
Kejtar
PostMaster General
and I'm waiting for my new rear spring pack and I'm hoping it's going to go in without a hitch :)
How about the rest of you guys? How's the preparations coming??? what major work needs to be done still?
Kejtar
i have everything to do.....
- Fab & Install front suspension
- Install Rear suspension / axle / t-case
- Fab & Install rock rails
- Maybe Fab & Install bumpers / Tube doors
- Install Gears / Limited slip
Geez, with all that to do in less than 2 months, it looks like we'll see you next year then :shocked:
Ivan
Putting in new tie rods and drag link with rod ends, finish putting touchs on trailer. I have two xjs to haul out from Tenn. Mine and the raffle xj. I bent my steering way out of whack last June when we were in Moab.
I jsut realized that I gotta change the diff fluid and put in the synth into the rear axle as I'm going to be towing a camper trailer........ the 80~140 is a PITA to get into the diff as it barely flows in that damn pump gismo....
Kejtar
what happened Tucker?
My daughter's getting married on the 11th. Between the expense and the rotten timing, I got hosed. Hoist a cold one fer me, will ya? I'll definitely be thinking of you folks while I'm sweltering in a tux.
I fought hard to change the date ... his family and some of ours have other conflicts and I lost the battle.
CHW and I are headed out in 43 days. :D
He's got some major axle/gear stuff planned - I survived our last little outing at Rausch Creek with no issues and am shifting into maintenance mode on RED for the duration. After last year's little surprise on Route 80, I ain't taking anymore chances about getting out there this year!!
Mike in NJ :patriot:
I got to change leaf springs, put the winch rope on the winch,
change wheels to a less backspacing,install the gas tank skid,
beaf up the tie rod, and get an alignment,and put the rear
bushwhacker flares back on.
Man, I had better get started soon!
Here's the short list. Some aren't that important and time will tell if they actually get done, others are a bit more important.
Front gear install
Axle u-joints
Steering box
Front shaft balance
Rear springs – re-arch
Lock (keyless entry) pin switch
Lube including double Cardan
Hood vents
Anti-wrap ladder bar with rework of t-case skid
Limiting strap front
Re-set caster
Water wetter
Heat shield (intake)
Heat shield (cat)
t-case?
SBS install x2
Aux fan relay –remote power
Driver door rust
Headlight covers- paint/replace
Fog lights remove (and replace?)
Gauges and pod (tranny and A/F)
Tranny temp sending unit and header
gauge pod install
Headliner
Rock rails paint
Tire balance
Hood alarm switch
Replace rear exhaust clamp
Check diff fluids
Steering wheel
Front springs replace - done
Front susp paint – done
Hood vent drip system
Low oil pres light/buzzer
Bones :skull1:
