When I turn on the marker/headlights my left turn signal is solid. There is no fast blink, all marker/turn signal lights work and flash correctly. I am using a Novita EP27 Flasher (when pulled it's solid though as well)
I am running LED 3157 bulbs and LED 194 on the side markers.
My understanding of how it determines the load on the line is what will cause this issue. I was under the impression the Novita EP27 Flasher would fix this issue. It clearly plays no part in that.
I have had this issue for a while now. I thought I knew what was wrong a few times but now I have resorted to assuming its an electrical short/ground.
Before I spend a lot of time checking harnesses with a multi-meter I thought I would double check here.
Other threads have indicated faulty bulbs, bad grounds, bad trailer harness (not even sure I have one) and the aforementioned Novita EP27 Flasher. Anyone else run into this issue and fix it?
